How much important the adobe flex builder 4 professional app builders?
I am in a confused state. What is the difference between Adobe Air and Adobe flex? Basically I am new and want to be professional in building apps. Which one is better? Is adobe flex builder 4 professional use? Help me please because I want to pick up one tutorial only.
Answered By 0 points N/A #185066
Hello
Here is the difference between Adobe Air and Adobe Flex,
Adobe Air is like a version of Flash Player it is for your desktop, you don't need a web browser to run it, You can create a web application and compile it to Air application, then you can install the app like any other software and it will run on your desktop. Adobe Flex it runs it through your web browser, If you want to create a Flex application, you need to run it with your web browser.
Hope it helps.
