I got an interview to work for one of the famous telecommunications company in Bangladesh.Â
I have three years of experience in the same field.
How much salary should i expect?
Really need your answers as soon as possible.
How much is the salary of Telecommunications in Bangladesh?
According by your question, I have some experienced with this telecommunication sector in BD. I'm Bangladeshi. If you have actual more than three year experienced you can earned a lot. But, you didn't mention your job post. If you mentioned it then I can figure it out correctly. With my explanation, I can serve you something. Maximum Salary 100,000 BDT you can earned from this sector. But the Average Salary 59,750 BDT you can think. And your salary will increase also with your lots of performance.
Best of Luck
Likhon How
Amount of salary for telecommunication sector in Bangladesh?In Bangladesh it is hard to guess salary for any post let alone in the telecommunication fields.There are many fields in telecommunication in bangladesh.Salary may depend on your post,location of job place etc.
As for example if you do customers service job for mobile phone companies in rural area you may get a salary of 5000 to 10000 BDT.And for the same post you get in cities 10000 to 15000 BDT.And again if you are a senior executive you may get a salary from 50000 to 120000 BDT.And some other telecommunication job where salary depends on your performance or productivity.
