How much the slideshow maker?
Hi Experts,
I want to know how much the slideshow maker. The need to buy this software and looking for good recommended vendors who sell this software. Anyone knows the exact price of this. There should be a silence and key. Thanks.
Zubin Lennon
Answered By 10 points N/A #132484
Hello Zubin,
The price of the Slideshow Maker application will depend on the version that you want. The following are the versions you can choose from:
  • Slideshow Maker – Windows CD-ROM  for  a Single User goes for $69
  • Slideshow Maker – Windows CD-ROM: 5 User – goes for $138
  • Slideshow Maker – Windows CD-ROM: Site License goes for $207
The Slideshow Maker makes it pretty easy for you to come up with slideshows with accompanying music, and they can also be used with a touch screen, plasma  as well as mouse. All you need to do after getting the version of your choice is to simply choose a set of pictures, and then add a music track and you will be good to go.
Carl
