How much space can Norton Samsung ace scan?
I have a Norton Samsung ace and I want to scan the whole system. To what extent can Norton scan Samsung ace? How much space can Norton Samsung ace scan?
Norton is providing mobile security for the entire system. Norton mobile security combines anti-theft features with power-full anti-malware to protect the entire system from theft and data loss, and it also provides a back-up system online.
So, you can thrust Norton.
Regards.
Norton Mobile Security provides the scan to all files and application updates downloaded on your mobile and it automatically detects the threats and removes them. It also gives you option to automatically scan SD memory cards for threats. Norton Mobile Security also gives you the facility of remote locate, lock, remote wipe and automatic live updates. And regarding, how much space it can scan is all depends on the memory you have used with your mobile i.e., if you have taken 32GB memory card with your Samsung Ace Mobile. Norton Mobile Security can scan whole 32GB memory for all files and detects the threats and removes them.
Notifications
