The SurfacePad is to protect the surface of your MacBook Air from scratches. It comes in two colors – red and black.
Will the company be releasing a gray or white SurfacePad?
How much is the SurfacePad and will it only fit a MacBook Air?
How much is the SurfacePad for MacBook Air?
SurfacePad is a leather cover tailored for 13-inch Macbook, 13 and 15-inch MacBook Pro, and 11 and 13-inch MacBook Air. It is not compatible with 1st Gen Macbook Air. It is designed to effectively protect your MacBook surface against dirt, stains, and scratches. Its soft leather cushion provides comfort in your wrist even if you work on long hours.
The SurfacePad for Macbook Air is available in two colors – jet black and pop red.
On the other hand, SurfacePad for Macbook and Macbook Pro is available in 6 designs/colors – smooth black, black with pattern, perfect pink, cyan blue, infinite grey and orange crush. The black SurfacePad matches the black keys while the other custom colors allow you to personalize and protect your MacBook in a cool way.
This magnificent leather cover for Macbook Air is $29.99 whereas $39.99 for Macbook and Macbook Pro.
