How much will a vehicle database in SQL cost me?
Hi!
I need a vehicle database which includes year, make, model, trim and photos. I hope someone here knows how much it would cost me and where can I actually get one?
Hi!
You can buy that Database Vehicle SQL here:
http://www.shopwiki.com.au/l/codebase-sql-database-developer
I'm not sure what kind of database you are looking for, but check out the site given above since they have a variety of databases listed. The price ranges from $25.00-$150.00.
Enjoy!
I will recommend you that you should go for some freelancing. If your requirements are dynamic I think build up sql utilities will not solve the issue. If you will go for any free lance it will cost you around 100$ but you will own that utility and you can make changes if some new requirements are there. If this is not the case than you can use any sql utility and it will also cost you 100$ plus.
Regards
I think you are looking for a database for some development work and not for business purposes. If so several options are available to you.
You can build your own database with the specific table and run insert queries to add records.
Find an Excel sheet of records or Access database and import to Sql Server or run a bulk query.
 Hire a Freelancing data entry operator to enter those data for you. You can advertise at https://www.upwork.com.
 Finally you can consider buying a database which will be the most costly option. For that purpose I recommend you to go through below links.
