ramgen
Posted on - 11/06/2011
Hi there!
I need a little assistance with my computers. I currently have eight computers, and I am starting to render farm for UDK and After Effects.
I am having a problem with one particular computer—the Dell Dimension 2350—because the Ethernet wouldn’t work in it.
I have tried the following drivers I found in Dell’s website but they all didn’t work—
I even installed Intel845GL chipset driver before I tried the Ethernet drivers but I didn’t find any luck.
I am including in this message the link to the specifications of my computer so you may use it reference:
http://support.dell.com/support/edoc…cs.htm#1101572
I am really hoping you could help me. Thanks in advance!
TERRY U
5 points
How to network eight PCs?
Hi Ramgen,
First of all you have to determine which type of Network card is installed on your desktop pc.
In order to identify the same, please check the following:
1- Check the rear of the pc, If the network card is located towards the bottom along with other PCI cards if any, it will be “The Broadcom NetXtreme Gigabit Network PCI card”
2- If it is located next to the USB ports in the center then the card is ” The Broadcom 4401 Integrated NIC”
What you need to do is to remove already installed network card drivers.
If you are using win XP, right click on my computer, select properties, select device manager, and locate the network card. Simply click on uninstall.
If you are using win7, perform the same steps, except the device manager will be on the left side of the pane on my computers properties.
However, before performing the above, you must have downloaded the correct driver for the network card.
If the card is The Broadcom NetXtreme Gigabit Network PCI card, then download it here:
Also do download here:
And if the card is: The Broadcom 4401 Integrated NIC then download it here:
Also please download this:
Just double click on the particular driver to install and after installation of driver, double click on the diagnostic utility to finalize installation.
Hope fully your issue will be resolved.
TU
I would say that the adapter itself is that the cause of this issue. Re-install the driver should take care of the problem with this particular computer. The dell support website you have posted should give you the guide on fixing this problem but apparently, it did not work for you.
If you still have the CD provided by your Dell manufactures, you can install this driver manually.
Go to Start, Control Panel
Hardware and Sound
Device Manager
Network Adapters
Click the (X) to expand
Highlight the Ethernet adapter installed
Left click update drivers
Insert the CD in the CD rom
Follow the installation wizard
Now, these steps will update the Ethernet card installed but if this doesn't work, try and consider replacing or installing another Ethernet adapter.
This is just to isolate the problem, because of the possible hard drive issue.
