How is new Google chrome browsing speed?
How is the speed of new google chrome 17 . Has anyone tried here the new google chrome.Shall I upgrade my browser or stick to the old one?
Hi
The new Google Chrome 17 has come with some new features such as instant searching, built in flash player and pdf reader. By instant searching you will start to get possible results while you have started typing key words on search engine platform. As you type more letters it will show possible matches. Moreover with built in flash player and pdf reader you do not need to install flash player and pdf reading software separately. In case of speed it has been seen that it works better for simple pages but for those pages containing heavy multimedia file it is nearly same. Overall you can work faster with new Google Chrome 17 than the previous versions.
Best of Luck
The latest Google Chrome is fast but the actual speed of the browser when accessing the internet and opening a website will still depend on your current internet speed. If your internet connection is already slow then browsing the web with Google Chrome will also be slow. If you are using Google Chrome and you haven’t updated yet, you should upgrade to the latest version.
Upgrading your web browser is not only meant to improve your internet browsing but to add more security to your browsing activities. Visit Download and Install Google Chrome. It supports Windows XP Service Pack 2 or higher, Windows Vista, Windows 7, and Windows 8. For Mac, it supports Mac OS X 10.6 Snow Leopard and higher. For Linux, it supports Ubuntu 12.04+, Debian 7+, OpenSuSE 12.2+, and Fedora Linux 17.
For Windows XP users, Microsoft Windows XP will be supported until the end of 2015. If you want to get the standalone installer, visit Google Chrome Offline Installer.
