How To Open Active Directory In Windows 7n
Hi. I am not very technical and I am supposed to install and open Active Directory on Windows 7. How to open Active Directory in Windows 7? Please reply ASAP. Thanks in advance.
Hi. To install AD on Windows 7, first download the package from the website and select the correct 32-bit or 64-bit according to your system. Next, after the package gets installed, try running it after which a message appears on which you need to click on yes. A number of terms and conditions will appear before you to which you need to agree so that the installation can proceed. After the installation completes, close the window. Open start and then type programs and features in the search box and then click on its icon to open it and select the option for turning Windows on or off. Next, start expanding the administration tools and finally the AD DS tools. Check mark the option which says AD administrative centre.
To learn how to open Active Directory in Windows 7, first click on start menu and then click on run. Next, an open box appears wherein you need to type dsa.msc and then click on OK. You can also try clicking on start, clicking on all programs, selecting the MS Exchange and then finally clicking on AD users and computers to open it and begin your work.
Hope we helped.
Notifications
