Hello Experts,
How to open dds illustrator? There are some database that uses and allows dds file format and how are they related to the dds illustrator, I am having a hard time on researching about this. Tell me more about this guys any tutorials and helpful website links will do help me a lot.
Thank you guys.
Double click DDS files on computer, the associated program will be launched to open the selected DDS file. Right-click on the DDS file and go through 'Open with' > 'Choose default program'. In the pop-up windows, choose a program as the DDS file opener.
That is for Windows, by the way.
Hope it'll help you.
Hello Charles Marry
Hope you are fine. You know, .dds is a plugin for Adobe Illustrator. At first you need to install the .dds plug in Like Nvidia or Crafts key. Search popular download forums like software informer or software topic for .dds plugin for your Adobe Illustrator. After adding a .dds plugin you will be eligible to open your database on Adobe Illustrator. Find your plugin first- filetips dot org can help you exactly. Hope this will help you.
With Thanks
Greaney Mary
