How do I open a file with a different program as that has been automatically set by default?
How to open a file with different program other than default one?
Hello Vicky,
All you need to do is to follow these simple steps :
Right Click on the file you want to open.
Select Open With option.
A Dialog box appears which asks you whether you want to select an application already present in the computer or do you want it to search for recommended applications online.
Choose the "Select program from disk" option and a list of programs appear.
Double Click on the required program and your file should automatically open with the specified program.
If you permanently change the option of opening it with a different application then Right Click on the file and go to the properties option. Click on the Change button besides the Open With option. then follow from step 2 above. Cheers.
