How to open ithmb Mac Lion
Hello Techyv Friends,
I am using Mac OS X Lion, in which I am unable to open ithmb extension image files. I am able to open the same files without any issue in my iPhone, Please advise me about how to open ithmb Mac Lion.
Thanks & Regards,
Wyman Zeb
Answered By 40 points N/A #148796
You can use an application called PicsAid.  This application is made to help you import and open ithmb files on your computer.  Go to the previous link and download the software it mentions, then install it.  After installing it, you need to open it and import the files you wish to view, and they will be automatically displayed.  Now you have the option to convert them into other formats like jpg or png, or leave them as they are.  Regards.
