Team Paul
10 points
Posted on - 06/25/2011
I recently downloaded a book from the Internet. The problem is, the extension of the book is .lit and I don’t recognize this format. I have tried Adobe Reader, Word and others but can’t open it. What software may I use to open this file format?
Please inform me.
Thank you.
How to open .lit file?
The format you mentioned can’t be opened by Adobe or MS Word. It is a file format of Microsoft Reader, to read a book online. You may download this software here:
After you install it, you can read the book. You must have, Internet Explorer 5+ to read and manage this software. .lit is a file format which is secured by Microsoft. So, no other company can use it. It is not an available file format, as PDF is more suitable now. You can edit it, as you wish, more easily than .lit. It contains more functions than .lit. So, it is more reliable.
If you're fine with any other software, then don’t forget to paste it here. I will try that software, to see if it is better than Microsoft Reader. But I don’t think other soft wares can compete with Microsoft Reader, like no player can easily play .WMV format file like WMP.
It's Very easy to open your file using Microsoft Ebook Reader Format just download this program so you can open your file or any files have the same extension so you can download and install it from this link:
and you should know that you can convert your .lit files into PDF files using this site as it's easy and simple to convert your files so see this link that you may like and may solve other extension problems you may face
Hope my Solutions Help You
