R Ocampo
10 points
Posted on - 01/10/2012
Hi All,
How to open multiple links at once in Firefox and Chrome
I have seen these add-on's on a clients Pc and was wondering where and how to install it.?
So can open many URL's in one shot.
Thank you
Hello there Buddy!
Personally, I am using Mozilla Firefox because it is lightweight and easy to use. There are 2 primary add-ons for Mozilla Firefox that can help with your problem. These are the Snaplinks and the Multilink.
I will help you how to install and use the add-on Snaplink.
Step 1.Look for the add-on, download and install it. Firefox might ask for you to exit all opened tabs in your browser before the installation, but after it restart your Firefox browser.
Step 2. After the Add-on successfully installed in your browser, go and search for any website that contains several links and drag your pointer by right clicking it and surround the areas with the multiple links. Now see what happens after you dragged the pointer, a rectangle green box will appear and inside it are also several small rectangle red boxes, these are your multiple links, easy right?
Step 3. Press the ALT Key if you want to move your mouse to another direction and Press the ESC Key if you want to cancel the action
Good Luck!
To do that you will need to use a third party application, and though there are several I will recommend for you one that is called multilink.
It is an add on that will let you open, copy or bookmark the multiple links that you want to open at the same time rather than having to do each of them individually.
For you to open, copy or bookmark links, what you will need to do is simply right click and hold to drag a box around the links that you want to take action on. The moment you release the right mouse button, you will be able to open, copy or bookmark those links as you want.
-Mathew Stone
