farhadazam
Posted on - 09/23/2011
My friend sent me a Word file which is password protected but he can't remember its password. I searched for a free password recovery software but I can't find any. If anyone knows a free software to recover or remove its password, please tell me.
How to open password protected Word file
If you want very fast recovery of your password then use this link
Unlock password of Word document:
First, open the document and do a "Save as …" specify rich text format (RTF). It will end up being something.rtf call.
Now open the RTF file by double clicking on it. It should look identical to the original Word file.
Final step: save the RTF file with a new name as a Microsoft Word document format.
That's all there is to do. You have evaded the read-only lock on the file from your boss sent you and they're good to go.
Thanks
mahmud_khalid
kimanif
Visit this site and you will be smiling after downloading and installing a software that will get past the protection password.
The Second option is if the MS Word documents meet the qualification of 40 bits. If it does decrypt it.
Right click the document, click properties.
Click advance in properties dialog box.
Uncheck the ENCRYPT CONTENTS TO SECURE DATA option under the heading compress or encrypt attributes.
Then click ok twice,
syonxu
In fact, There are various password removers is proved to be a helpful tool for users to recover Word file password. The average person will use Word Password Decryption.It supports brute-force attack, brute force with mask and dictionary attack which can restrict the search area and shorten the password recovery time. Following is a simple guide to recover word document password.
Step 1: Download and install Word Password Decryption(It is small)
Step 2: Run the program, and then click Open to import your locked Word document
Step 3: Select attack type, and then click Start to recover password
Hi Farhadazam
To get more techniques to resolve this issue pay a visit this Techyv post too.
Recover password in ms word
