Hi. I have recently started using MS-Word and I am not very known with its features and functions. I have prepared a PDF file which I need to open in Word 2007. How to open a PDF file in Word 2007? Please reply ASAP. Thanks in advance.
F Samuel
10 points
How To Open A PDF File In Word 2007using Simple Steps
Hi. To learn how to open a PDF file in Word 2007, first open MS –Word by clicking on start, then clicking on MS-Word. Next, click on new to create a blank document. Click on the file menu followed by the open option so as to open the file which needs to be viewed. Once the open option has been selected, select the source as to where the PDF file is stored. If it is on the computer itself then select computer and if it is on an external drive, then select the option of drive. Browse the PDF file and then open it. Click on OK to open the PDF file. After the file opens, you will be shown an option for enabling the editing.
You can click on it to be able to edit the document. Scroll through the pages and navigate through them as you do in normal Word files.
Hope we helped.
