How to open PDF using java code?
How to open PDF using java code? I would like to know about opening PDF form in java created systems. Is there a way you can share or illustrate with me the proper coding technique? Tutorials will also help me a lot along the way.
Thomas.
Best Answer by JOY Schilling
Answered By 5 points N/A #86548
Hi Thomas,
I have a code to open a PDF file with java. I had learned about this code from my Java Tutor. This is very easy to learn and understand. Here is in windows, we know that there is a file named as "rundll32". This is a DOS command which is also used to launch or open a PDF file.
Code:
package com.joy.jdbc;
import java.io.File;
//Windows solution to view a PDF file
public class WindowsPlatformAppPDF {
 public static void main(String[] args) {
   try {
  if ((new File("c:\JavaCode.pdf")).exists()) {
   Process p = Runtime
      .getRuntime()
      .exec("rundll32 url.dll,FileProtocolHandler c:\Java-Interview.pdf");
   p.waitFor();
  } else {
   System.out.println("File is not exists");
  System.out.println("Done");
     } catch (Exception ex) {
  ex.printStackTrace();
Code Explanation: Simply this code finds a PDF File at a path C:\JavaCode.pdf. If file exists then it will be opened otherwise you will get message as "File is not exists".
Thank You.
Answered By 0 points N/A #86549
Is there any way to open a PDF file on a Java application that will work independently of the platform on which it is used?
Batch File in Windows is able to perform this task, but I am looking for a way to open PDF file irrespective of platform.
Here is a link to website to open a PDF using Java code.
Answered By 0 points N/A #86553
Hi Thomas,
Here are the methods you can use you need to follow.
> By using “rundll31” – this is the Windows Platform Solution
*For Windows, you can use "rundll31" command in order to open PDF file,
> By using “Awt Desktop” – Cross Platform Solution
*This Solution Awt Desktop Cross Platform Solution is much recommended. This works in windows and Mac Platforms.
Hope this will help.
Answered By 0 points N/A #86555
Hey Thomas,
  • You don't need to go through any big tutorials for doing this simple thing.
  • Desktop open(File) is function which launches the associated application to open the file. It's present in package java.awt.Desktop.
  • Try the code in the file attached.
  • The code performs simple function of opening a file using it's by default application.
Hope this works for you.
Answered By 0 points N/A #86551
Hi Thomas,
1. To open PDF using java code we suggest a syntax:
https://docs.oracle.com/javase/6/docs/api/java/awt/Desktop.html
And 1+ for none-window-only solution. – james.garriss
2. You can use this method which has made that Windows infiltration obsolete:
Desktop. getDesktop() . open (new File("C :/C.pdf"();
NOTE: Put the file name inside double quotes to work around the space problem.
