anonymous
7060 points
Posted on - 04/24/2012
I want to do something in the service menu of my Roland SC-545EX but the problem is I don’t know to enter the service menu of the printer. I know that after entering the service mode menu I can do the job next to it because it is a menu driven system. All I need to do is just search for the function on the menu. I know that expert on this site can give me the code.
How to Open Roland SC-545EX Printer Service Menu?
If you elaborate something more about your questions, it may be create more perfect relief for you. However, You want to know about Roland SC-545EX printer. To enter into it's service mode you have to follow this step. Just being with the steps-
When you want to enter into the service mood, you have to use arrow key like- left, right, ups and down keys.
Step 1. You have to make sure that the printer keeps off at the front panel.
Step 2. But you should now, turned on the printers back panel.
Step 3. Follow the key pressing instruction given below-
UP-LEFT-RIGHT-DOWN
Now, LEFT-DOWN-RIGHT
Step 4. Now you have to turned on the front panel. While doing it, press down the left and the right at the same time. Make sure it.
Step 5. May be your problem is solve now.
