How to open rtf Plugin for edition
I wonder if something can open rtf plugin made for edition. I need to insert some different names to the rtf for my work. Working with text editor is necessary because opening with MS Word making my document invalid. So, I am searching for that text editor which could format that rtf file, for example, by making its text in different colors. Thank you for your help!
Answered By 80 points N/A #143191
Hello Angela,
You can use the in built "Wordpad" in windows operating systems to format a rtf file. It can be used to change text color and do some more formatting like Bold, Italic and etc.
Also there's a way to convert a rtf file to a DOC file. If you can open it in office Word, after opening Click Save As and save it as a DOC file. If you can't open it in Word open it in Wordpad and Click Save as and save it as a "open office XML document"(docx). Then you will be able to open it in word and do necessary formatting.
