I was once downloading some audio tutorials when I downloaded this audio file with the format SWF file. I tried to open it using the necessary softwares like, VLC Player, KMP Player etc. But I was unable to open it. Which software do I need to open this file and listen to the audio tutorial?
How to open a SWF file?
SWF files are a different kind of files not supported by normal video programs like VLC, Media player etc.
I mean these all applications may require extra codec downloads to support SWF file type.
And there can be lots of problems installing the CODEC. Its better you can download Flash player to play SWF files from Google. You can find programs on this site.
There are many other sites you can find many programs which support this kind of files.
Hope you will find many programs to run the file with extension .swf and become successful in running it.
SWF file format is a multimedia file that is controlled by Adobe. This file may contain animations/animated display graphics created using Adobe Flash (Macromedia Flash).
Below is the list of programs that can open/play files with SWF file format:
1. Adobe Flash Player.
2. Eltima SWF & FLV Player (Windows OS) / Eltima Elmedia Player (Mac OS).
3. GRETECH GOM Player.
4. Media Player Classic.
5. GlobFX Swiff Player.
6. Web browser with Flash plugin.
