How to open swf file in a mpcstar player
Hi. I have this mpcstar player and when I open a swf file, it has no sounds even I play it. Why I cant open a swf file in a mpcstar player? How can I open swf file in a mpcstar player?
Hi Petrusic Parisi!
MpcStar supports with different file formats such as avi, mp4, asf, mkv, ogm, rmvb, mpg, mpeg, mpv, m4v, rm, mov, rmvb, 3gp, 3gpp, 3g2, 3gp2, flv, vob, ifo and SWF.
Regarding to your problem, here are some tips you may do:
1. Make sure that your MpcStar is installed correctly.
2. Play your swf file to other media players that can support this format. This is to see if your file is corrupted and if it is really having a sound.
3. I also suggest that you may test some other swf file to make sure that all your files with that format are not playing right to MpcStar.
4. Play another file with different format to know if swf file is the only one has this problem. If all or many of different file format has encountered the same problem I recommend you to install and reinstall MpcStar but if the same problem is still you should download the latest version of this software.
