How to open VSD file on windows XP
Hello expert, My friend is using windows XP on his PC. He asked me how to open VSD file on windows XP. Can you explain me to guide him on this difficult situation?
Opening *.VSD files in Windows X.
VSD files are files that contain diagrams or schemas of a specific system (like a network infrastructure). They are created using Microsoft Office Visio and they can be views using the same software or a viewer: Visio Viewer.
Below you can find the download page for Visio Viewer 2003. Download and install it and you should be able to view VSD files.
http://www.microsoft.com/en-us/download/details.aspx?id=21701
Vsd file format is a filename extension for Microsoft Visio.
VSD stands for Visio Drawing. It contains diagrams and flowcharts wherein Microsoft Visio as a vector-based program was used creating it.
In order for you to view it, you need to have either Microsoft Visio Viewer or Microsoft Visio itself.
you can download them thru this link:
Microsoft Visio Professional 2013
https://www.microsoft.com/en-us/evalcenter/
Microsoft Visio Viewer 2013
http://www.microsoft.com/en-us/download/details.aspx?id=35811
