How to open a wab to excel?
Hi guys,
I have five .wab files that are need to be opened. My secretary handed me those files yesterday, I am just thinking if I could possibly open a .wab file using Microsoft Excel application.
I have to ask first before doing any move.
Expecting some help, thank you.
Best Answer by James Kalester
Answered By 0 points N/A #173389
Hello there,
When you go to the Windows Address Book, save it as . CSV and then try opening it in the Excel.
You will now be able to open it in excel.
This will surely help.
If it doesn't, either way you can download a wab to excel converter available free of cost.
This will definitely solve your problem.
Below given link will help you with some free converters.
Have a look.
http://www.freedownloadscenter.com/Se/HOW-to-Open-Convert-WAB-to-Excel/
Cheers!
Answered By 5 points N/A #173391
Dear Virginia Adams,
You can open .wab files with excel by changing it to .cvs through the following steps:
1- Go to outlook express then choose export from file menu.
2- From export menu choose Address book.
3- Select text file you want then press export.
4- Type your file name in the save as menu that will appear.
5- Click next then finally click on finish that will be with .cvs extension.
