How to open a .wpd file as I have tried to open a .wpd document into a Microsoft file, but I cannot be open its always show error, so is there is any way to convert coral Word Perfect (.wpd) document into a Microsoft word document. Can anyone help me to open this type of file it will be very helpful for me.
How to open a wpd file
Yes, there is a way to open .wpd file into word document. Follow these steps which are illustrated below.
1. First, you have to open a word document, Display the file menu and after that click open.
2. Here a dialog box appears, you will have to select the All file types (*.*) from the files of type drop-down list.
3. After that you have to use the look in drop-down list to locate the word Perfect file you wish to convert.
4. Now you have to select the WordPerfect file and click the open button.
When you click the Open button, Word converts the document and opens it. After you have opened the WordPerfect document, save the file in the .doc format.
5. Now click the file menu and click on Save As.
6. Select the word document from the save as type drop-down list
7. Now click save button and your file will be saved as a word document.
As what I posted here: What is WPD Document, it says that most versions or the majority of the versions of Microsoft Office Word can open a WPD file. But it doesn’t mean that all versions including the latest can open a WPD document. If you tried to open a WPD document using a newer version of Microsoft Office Word and it failed then that means it is not compatible.
If Microsoft Office Word can’t open the WPD document, another option is to use OpenOffice Writer. If you don’t have OpenOffice Writer, you can download the entire OpenOffice package from Apache OpenOffice 4.1.1. This is the latest version released on August 21, 2014. On the other hand, if you don’t want to use the Apache OpenOffice or even to install the OpenOffice Writer, you can also open a WPD document by converting it to a DOC format.
And you can do this online. Visit Zamzar Free Online File Conversion to convert your WPD document or file into a Microsoft Office Word format. This will allow you to open it in any versions of Microsoft Office Word.
.wpd is a Corel WordPerfect extension and WPD denoting word perfect document. Corel WordPerfect is outdated hence to open the extension you will need to rename your file extension from .wdp to .doc To rename it just right click on the file>rename and give it a name and add the extension .doc for example important.doc After doing that Microsoft word should be able to open the document.
Alternatively
1. Open Microsoft word-click file-open
2. In the file type at the bottom of the dialog box, select the drop down menu and change it to all files (*-*)
3. Browse the file and click ok
4. Word will automatically convert and open it
