techieagent
Posted on - 09/24/2011
Well I have a blog in blogger.com and a Google adsense account. I'm targeting to make more clicks daily and I've heard parsing is one of the techniques that I need to consider. The problem is, I don't have any idea about parsing an adsense code to your blogger template. Can someone tell how to parse Google adsense code in Blogger? Thanks.
Dplus
How to parse Google Adsense Code in Blogger
Hi
friend you want to make more traffic in your blog. so parsing is the best option to gather visitors. i think you can add new or free domain name for more traffic. parsing is important so you can buy from search Google Adsense parsing and buy instant if you have bank account or credit card. it will get successfully but if you have not account or credit then you can pay by another credit card or master card number. your parsing code and version you have to add your Adsense blog. you can solve by this solution
best regards johir raihan
thanks
