How to Password Protect outlook.pst?
In Outlook 2003 from the top menu, Choose Go then Folder List, then click on Data File Management. In Outlook Data Files, click on Settings, then Change Password; in Old Password leave this blank if this is the first time that you are putting in a password and then type the New Password.
This image has been resized. Click this bar to view the full image. The original image is sized 953x768px. |
Next time that you open up your Outlook, it will prompt you to type in your password.
In Outlook 2007 and 2010, the procedure is quite similar to that in Outlook 2003 procedure.
From the top menu, choose Go then Folder List, then click on Data File Management. In Outlook Data Files, click on Settings, then Change Password; in Old Password leave this blank if this is the first time that you are putting in a password and then type the New Password.
This image has been resized. Click this bar to view the full image. The original image is sized 969x768px. |
All done! Simple enough isn’t it, to secure all your Emails, Contacts, Calendar, Notepads, etc… from within your Microsoft Outlook?
Note: This Tutorial is appropriate for Personal Use only.
There are different ways of creating a .pst file with Microsoft Office Outlook.
Here is one where you create the .pst file while Microsoft Office Outlook is up and running.
The new .pst file appears in the Data File area. When you create a .pst file, you can add a password of up to 15 characters.
If you click to select the Save this password in your password list check box, note the password in case you must open the .pst file on another computer.
For other information you might need to visit
