How to paste inside patterns in objects at AI
Asked By 7060 points N/A Posted on -
I have been using Macromedia Freehand at work for a few years but I've recently decided to try Adobe Illustrator (for a change/ to upgrade) in making garment spec sheets. However, I can't seem to figure out, how to easily paste inside a pattern in an object. Is there a paste-inside option in AI (because Freehand has) or is there an alternative and easy way to do it in AI?
Please help. Thank you.
Answered By 15 points N/A #83202
Here following my example :
  • I even have designed a type using Celebrity Device, Pucker and Bloat outcome In Photo shop.
  •  Next, I need to transfer it into Photoshop, therefore opt for} the type and select, Modify & get; Content (Ctrl+C) to do it again the textual content.
  • Make a alternative papers in Photoshop and insert the textual content by choosing, Modify & get; Paste (Ctrl + V).
  •  In the corresponding discussion box, select sensible Item stereo option and then press OK.
  •  Your textual content ought to be copied and pasted as a sensible Item in Photoshop, hit Get into on the num pad or check-mark on the option Bar to make it.
  • Now for a few factors I need to edit the content. For that, basically double-click on the sensible Item symbol within the Part Scheme, then press OK.
  • The object/shape can instantly start in Photo shop, edit the content or if you have got any textual content or type do the edit as you would like, here I customized it a little and included a another the actual type and furthermore customized large of the content to red.
  • After you're grateful with the edit, select Computer file & get; Preserve and turn the file and there you are the changes are going to be instantly replicated in your Photoshop papers.
Thanks
