How to perform avg dos scanner?
How to perform avg dos scanner? Is there a keyword to be entered in ms dos command prompt and will automatically scan all the software, files and data that is being saved in the computer? If there are some ways give me some tips and a step by step process. My current operating system is windows xp.
Waiting for your support.
Answered By 0 points N/A #175313
Scan your computer with AVG boot scan to get rid of viruses and overcome spread over other files. to do boot scan have to type specific keywords and can handle different situations while scanning using keywords easily than manual scan each drive.
Search for avgscanx.exe which is in c drive program files select avg folder search avg version file. type /SCAN =path;path/ to specify particular drive path and type /Help for any help in dos mode and enter /COMP to scan whole computer all drives and to choose some files skip from scan enter /EXCLUDE.
For more information goto avg site and click support button then search your problem in frequently asked questions.
Hope these shall helps you
Thanks
