Hi techyv,
How to perform file mp3 recover? This is my first time to use the Windows XP operating system since I am a Mac OS user, my business partners suggested and lend their computer desktop for me to create some reports for next week’s business activity. I would like to recover the deleted mp3 file, but how? Show me the proper way of recovery.
Hoping for your help.Â
Wassup Virginia, your query is easy to solve, first of all you need to realize the music cannot be recovered manually, you may need a software such as EASEUS data recovery wizards. This software will search all music files lost due to format, partition, or even deleted by mistake and recover.
You will need to download it from the website.
Follow the prompts required and install the software.
Once you install the software, stop using the music player if you were using it . Launch the software and select the reason the mp3 files got lost.
Click on the checkboxes to select the file types you want to recover.
If you want to find the lost files, you can click on 'Search all lost files automatically' this will search for all files.
To ignore the bad files, you just click on 'Bad sectors'.
Click on the disk volume where the mp3 files were located and click on 'Next' to start searching.
Sooner or later you will see the files.
Choose the file you want to recover and click on 'Next'.
Select a directory and click on Next to save the files.
I hope this solves your query.
