Hello experts,
How to perform a google configure mobile? My Android Samsung Galaxy Y Mobile Phone has a Google interaction problem, when I tried to open Google Chrome browser it crashed and never let me view some important content on a specific website. I need your help to trace the main cause of this problem, I got a fast wireless internet connection.
How to perform a Google configure mobile?
Hello Stephen,
The way I know to perform a Google configuration is little scary but it will do the job for you. First take a back up of your mobile phone. I would suggest you to transfer everything to SD card and remove it before configuration. Factory resets your mobile it will format your mobile and it will restart. The first screen you will see, will be from the Google configuration screen. Follow the steps and add your credentials. It will be done. Insert your SD card after that.
Thanks
If you want to perform a Google configure on your mobile, your problem is programming . First, you need to complete a factory reset. Then, your phone will restart automatically. When your mobile opens, you will see a new screen. The problem should be solved if you follow these steps.
Thank you.
