Hello experts,
How to perform Google playbook import PDF? I got my new playbook and was unable to import my PDF form. What is the main cause of this problem? Should I download some plug ins to enable importing of PDF files? Give me some answer; I need this to be done as soon as possible.
Thank you.
Hi, Amanda!
You won't be able to read your PDFs with the Google Playbook alone, but you may read a PDF file with a simple application. This application is best recommended for Android tablet users. Moon + Reader Pro supports lots of files, including PDF. It has also been said that this is the fastest PDF rendered on Androids. Here is the link: http://www.moondownload.com/download.html
Hope this helps.
Hello Amanda,
To import PDF in Google playbook you need to use an application. There are so many PDF readers available on the internet. I can suggest you a few names such as: Amazon Kindle, EPDF, Moon+ and more on. You can choose any of these because all of them are good. Hope this could be a help.
Thank you
