How to perform hp touchpad clear history?
How to perform hp touchpad clear history? When other user or people use my touchpad I don't want them to see any of my work or username and password that is why I want to know more about this for security purposes.
Thank you.
Best Answer by Prince Medalla
Answered By 0 points N/A #147806
Dear DonalBambie,
Clearing the history of HP touchpad is easy. If you want to delete browser’s history then:
After browsing open the application menu bar. Go to preferences and click on Clear History.
For deleting call’s data press center button if you are on a program, hold down up arrow icon. Click on Clear call history two times from phone and video calls.
Answered By 5 points N/A #147807
If you want to delete your browsing history on your hp touchpad, simply go to your browser. When the browser is opened, click the top left corner of screen. Then tap the down arrow that says "web". Then tap preferences. Click or tap the specific history item that you want to delete and slide to the right. You will then be prompted for deletion of the item.
