Hello fellows,
How to perform Joomla online printing?
Can we make a code for Joomla to automatically print some data from the system?
For example, a hotel reservation website that will make a connection between online print outs.
I need your help.
Eric Ericson.
How to perform joomla online printing?
Hi, we will require online printing forms setup duplicating and the web site is ww.gotprint.com process as well as order setup. This will required to be in a Joomla Component.
We have remember that this component will be installed within Joomla environment which will allow all kinds of different aspects printing to be configured like this.
www.gotprint.net/g/uploadBrochure.do
www.colorfxweb.com/products/brochure-printing.aspx
www.vistaprint.ca
Example – forms will be –
Business Card,Booklet,Bookmark,Brochure,Calendar,Flyers etc..
The component will also include-
Dynamic Product Calculator, Adding print jobs to a cart, Shipping, Order History, Payment Gateway – Paypal, credit card etc.
Hi there Ericson Eric,
If I understood you correctly, you are looking for a way to automatically print reports. Unfortunately, something like that will be hard to accomplish and there is no such Joomla plug-in yet on the market.
The first thing you should do is to find the component you'd like to use for creating reports. After you've made a choice, you should recode the component and part of the Joomla core files to enable automatic print.
I'll be more than happy to help you with that once you decide about the component you'll be using.
Best regards,
Drake Vivian
