Hi guys,
How to perform jquery split screen? Share with me some video tutorials or your personal idea about jquery coding to split screens. I need it for a jquery project and your suggestions and advice regarding this issue will be a great help.
Expecting some help, thank you.
How to perform jQuery split screen?
Hi dear, It is hard to teach you jquery splitting in a single step. However I do not have video tutorials. But I hope it work for you if you know basic about jquery. Create code like this:
One side
Another side
#Sampleplitter { Define height, wide and other properties here } And I think this two page will help you: http://methvin.com/splitter/ and https://github.com/asyraf9/jquerymobile-splitview
You can use simple HTML code with frame sets to split screen. You can try below code
<html>
<head>
<title>HTML Split Screen Example</title>
</head>
<frameset cols="30%,70%">
 <frame name="left" src="left.html">
 <frameset rows="75%,25%">
   <frame name="top" src="top.html">
   <frame name="bottom" src="bottom.html">
 </frameset>
</frameset>
When using Jquery to achieve split screen functionality you can use a third party plug-in which will reduce fair amount of code you have to write by your own. A plug-in is available in below link with sample code.
