How to perform Mac unload module?
How to perform mac unload module?
I want to know about unloading, removing and deleting module on mac operating system.
Can you give me a step by step process or method to be followed so that I will be able to know how it works and to fix this issue as well?
Thank you.
Answered By 0 points N/A #181954
To remove an application on mac operating system do the following steps: Change "My Processes" at the top to "All Processes" in the Activity Monitor. Then quit the application which you want to remove. In the finder search the application name.
Click the + button below the search term to add criteria Click the search criteria drop-down and select "Other…", then "System files" Click the "don't include" and change to "include" Sort by name, kind, date, etc. to identify components of the app Delete all files and folders related to the app After all these steps please restart your system because a reboot might be necessary to completely remove some apps.
