Hello experts,
How to perform outlook 2010 delete multiple folder?
Last week I tried to add some folder in my Microsoft outlook application, it was automatically duplicated. I got 2 or more folders with the same folder name and content.
How will I be able to solve this issue?
Hi Young Hernandez,
I have made a research regarding with your concern and it is seemed that Google has a lot of information about this matter.
I have seen a lot of possible answers with your concern.
Attached herewith is a link of some good forum and sites that has a possible solution.
Kindly check the links below:
Hope that it would help you a lot.
My dear,
You will be able to use OutBox 2010 to delete multiple folders if you read the following website to find the solution to your problem:
Good luck.
