Any Hill
30 points
Posted on - 10/23/2012
Hello experts,
How to perform remote view log 64 bits? I am currently using windows 7 64 bit operating system and with a processor speed of 2.1 gghrtz, I just want to know about remote view log access in this windows 7 64 bit operating system. The setup or setting flow is what I want to know. I hope you can help me.
Thank you.
Want access log in remotely with feature in windows 7 go to event viewer select node which is in root level like local then press connect to another computer option in action menu then enter ip address of computer in remote mode for the next computer then choose connect as another user option then press set user option give login details then press ok and again ok.
Hope these shall helps you
Hi Any!
Are you using Geovision Remote ViewLog? If yes, then follow these steps to set it up.
Geovision DVR Server Setup:
Click on Configure.
Select System Configure.
Go to the General Settings tab and the Start-up box, and check TCP/IP Server.
Click OK.
Click on Configure again.
Select Password Setup.
Go to Remote Authentication Setup.
Check all three boxes.
Click Setup Server.
Set to default the Server IP and Server Port.
Type in your Authorized ID and Authorized Password.
Click OK to save the settings.
Click OK to exit setup.
Geovision MultiCam Remote View Client Setup:
Click on Connect.
Select Internet/Intranet TCP/IP
Type the hostname of your Dynamic DNS service or the IP address of your router if it uses a static IP address.
Enter port 3550.
Enter your Login ID and Password in the server.
Check Save password if connect success.
Click Login.
