How to perform samsung wave contact export?
Hello fellows,
How to perform Samsung wave contact export? I would like to export all my contacts in my computer with windows 7 operating system. Can you suggest some ways to make it done properly? I would love to follow some instruction from you guys.
Charles Marry.
Answered By 0 points N/A #187485
Samsung Wave uses BADA Operating System that is part of Android OS. You can create a Gmail email account and associate this account with your Android Samsung Wave. Afterwards, connect your handset with wifi to internet and Sync your contacts just once. Whenever it has been completed go to your gmail account through your pc and choose Contacts in the Email options. Here you can now have all your synced contacts and you can import them as csv excel file for backup.
Good Luck.
