How to perform some exporting php to excel?
Hello fellows,
How to perform some exporting php to excel? Is it possible for me to record all my php codes in an excel application? I really need some assistance to export those codes and gather them all in my excel sheet. This is to make sure that I will get some back up record for the codes.
Marie Philips.
Best Answer by Ornelas Harris
Answered By 5 points N/A #165198
A few excel plug-ins can help importing php codes to the spreadsheet with great efficiency. Spreadsheet_Excel_Writer plug-in is very useful for this purpose. The below link will give you option to download the plug-in and also will give you details about the possible bugs and solutions for them. You can also choose suitable version of it that is required for your Operating System.
http://pear.php.net/package/Spreadsheet_Excel_Writer/download
Answered By 0 points N/A #165199
Yes, you can. You can take a backup of your PHP to a excel sheet. There are many processes to do so. I think most of them are effective. I can suggest one. If you think you can do that, you may take the PHP codes to a notepad and them copy paste that to the excel sheet.
Hope that helped you.
