How to perform Toshiba webcam set luminosity?
Hi guys,
How to perform Toshiba webcam set luminosity? How can I possibly adjust the luminosity or the measurement of brightness in the webcam so that it will be clearer for to use during video chats using faccebook and yahoo messenger. If you know the proper set up please let me know.
Expecting some help, thank you.
Answered By 0 points N/A #182457
Do you have Skype? If you have skype, you can adjust the settings there. Once logged in, go to preferences. Click the camera settings. Open Properties. Once there, you can adjust the brightness of your camera.
Another way is to search for Camera Assistance Software which is installed in your computer. You can adjust the brightness by following their on-screen prompts. If you don’t have the software, download it here: https://support.toshiba.com/
Lastly, the other solution is going to Web Camera Application. Go to your Toshiba folder located at Program Files. From there, open Utilities and you’ll see the application. Open it and adjust your camera settings.
