Hello experts,
How to perform an ultraiso fix burn? An ultraiso software is capable of handling some cd and dvd burning files. But when I try to copy some files from a dvd an error occurred saying that unable to transfer file. I am thinking that the file was not supported; my current operating system is windows 7. I need your help to resolve this issue. Thank you.
Steps to burn files to DVD and CD with UltraISO:
Put in the blank DVD/CD into your DVD/CD writer drive. Close the DVD/CD drive and wait for your system to identify the blank disk.
Open the UltraISO.
Push "Ctrl+O" to take up the release menu once within the UltraISO software program. Choose the DVD/CD file that you desire to burn onto blank DVD/CD. Press "F7".
Press the "Burn" command button and disk burning will start. Wait to finish the burning in the disk and then push "Enter" to close.
Best regards,
Heather marie
You are right that UltraISO software can also be used in burning CD/DVD files. However, it matters If you are having a full version of UltraISO or a trial version of this software. Trial version has a limitation on the file size that you wish to burn. UltraISO has built-in burning engine to burn CD/DVD images. If you wish to enjoy the full-feature of UltraISO you may access the software, download it from:
