moss mathew
20 points
Posted on - 08/26/2012
Hi Experts,
I want to perform VersaCheck for Mac. How do this? I am having much as on Apple PCs. I tried on the Control Panel at user settings. But I do not know the exact steps. Help me to achieve this. Thanks.
Moss Mathew
How to perform versacheck for Mac?
Hello Moss,
You can perform versacheck on your Mac using an application called ChecksQuick. This application will enable you to write out all the checks for the bills you have with just a few mouse clicks with the use of the checks that you get from your checkbook.
You will need to enter the names, amounts as well as the account numbers for all the bills that repeat themselves into the ChecksQuick application only one time. When you need to pay the bills, you will just need to choose those you need, and then you will put them into a printer and then click Print.
Hi there,
For usage of Versacheck on your Mac you have to install a software developed by G7 Productivity Systems specifically for QuickBooks, it installs separately but it works under printer dialog inside the QuickBooks program.
You will need Versacheck 2010 for QuickBooks.
Installation steps:-
Download and install from the internet.
During installation it will add automatically to your default printer.
Use following it is recommended
http://www.intermate.com/
Register software and launch the program,
Hope it helps!!
