Hello experts,
Well I just want to ask if it is possible to make wpf image edit in notepad. How to perform wpf image edit in notepad? If there are some instances that this is possible can you tell me how it can be done and works in just a single notepad? Your suggestions and ideas will probably help me a lot.
Those kinds of files cannot be opened or edited with just notepad. The closest you can get to notepad is Microsoft Word 2010.
Here's the download link if you don't have it yet http://www.microsoft.com/en-us/download/details.aspx?id=29295.
Other software you can use are Corel WordPerfect Office x6 and Adobe Capture, these two are for more advanced users so I suggest you go with MS Word.
