Hi Experts,
I am having yahoo photo upload. Currently it is not working. It get suddenly shutdown. Can anyone tell me  how to reinstall yahoo mail photo upload handy?It might have crashed due to bulk photo uploads done by me.
Jonathanchandler
How to perform yahoo mail foto upload handy ?
If this is the first time that this happens, try closing the application, restart your computer then try it again. See if it’s back to normal after rebooting your system. If still not, try to do a clean installation of the program to get rid of corrupted files in the system. Uninstall the program then restart your system when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your computer, use disk utility applications like PC Tools Performance Toolkit, or Norton Utilities. Install the program again then see if you are now able to use it.
If you are using Yahoo! Photos Easy Upload Tool, try downloading its installer again. It’s maybe because you are using an older version of the program and it is no longer supported by the site. For more information about this, please visit How to Install the Yahoo! Photos Easy Upload Tool in Internet Explorer.
