How To Permanently Block A Website Which Is Harmful Or Unsecure
Hi. I have been getting a lot of spams from a website lately. I want to block it but don’t know the steps which need to be followed. How to permanently block a website? Please reply ASAP. Thanks in advance.
Answered By 2105 points N/A #116854
Hi. To learn how to permanently block a website, first open the web browser and enter the IP address in the address bar provided. Next enter your username and password associated. Then, find the section where you can block websites, PCs for certain time in the day. You need to mention the content as well as the users which are to be restricted and then save the changes made.
Alternatively, you can open the Windows Explorer and then navigate to the drivers in the C drive. Next, click on hosts twice to open it in a notepad. Then, locate the line for the localhost and create a new line by clicking on enter. Type the websites which you wish to block and save the file to save the changes made. Then, make sure that all the options in the user account are selected while you click on the host’s file, view its properties and click on security.
Hope we helped.
