How to permanently keep xp desktop sticky notes in a position
I have an xp machine and I love using xp desktop sticky notes, the problem is when I stick a note in some position on the desktop and shutdown the pc, it wont be in that same position when I log on again, does any one know how to permanently stick the notes?
Best Answer by Dawn Andarson
Answered By 5 points N/A #153520
First open Sticky Notes by tapping the start button , typing Sticky Notes in the search box, and then tapping Sticky Notes in the list of results. Press the Tools menu, point to options, and then tap open at Startup and  press Always on Top to permanently keep it position on your desktop.
Answered By 0 points N/A #153521
Hi Asten,
I don't really think Windows XP would support the thing which you want. Windows does not support that. You cannot keep the position of the sticky note fixed all the time.
Alternatively, I would recommend you to install an alternate sticky note software.
You can download it from here: http://www.7stickynotes.com/download.php
Hope this helps!
Drianna allen
