denine punk
Posted on - 03/07/2013
Do you have any idea how to play 3d in vlc player using 2D movies? Is this possible? I have one downloaded 2D movie which I can’t find a 3D version of so I can’t play it on my DVD player. I’m thinking of using pc programs like VLC and make it work if it’s possible.
How to play 3d in VLC player using 2D movies
Hi Denine,
I was searching for a solution to play 3D in VLC using a 2D film, but i think that you can make it with the VLC Players, you can only do the opposite playing a 2D movie using a 3D.
You can use other software or players to do this, there are many converters from 2D to 3D like DVDFAB, this software has a very high quality application to convert. Also exist the "PowerDVD" Player which can do this conversion as well as "3Dfier" and then you can enjoy your 3D film.
Douglas
