How to play d link dat files software
I have a lot of files that I cannot play.
How to play d link dat files.
Is there any codec for this?
Is there any other software that can play this kind of file?
If there is post the download link here.
Best Answer by Toni Linscomb
Answered By 0 points N/A #136279
You can play DAT files but you must convert DAT files using a software converter. I recommend you to use the ImTOO Date Converter. It is easy-to-use DAT file format video converting software, capable of converting DAT to AVI, MP4, 3GP, WMV, DivX, MPEG-1/2/4, MP# and MP4 audio and FLV video.
It helps you to convert DAT files, change video and audio limitations, modifies file size, rip file and many more.
Here's how to download:
  • Go to www.imtoo.com
  • In the Products section chooses Video Tools
  • Search for DAT Converter and click
  • ImTOO DAT Converter will appear on the window
  • Click Free Download
  • Download start automatically
Best regards,
Heather marie
Answered By 5 points N/A #136280
A DAT file extension is a data file. The file types use DAT as extension includes video files, Email attachments or data files. In most cases people tend to think DAT file is only a video file, but remember it’s not correct on every occasion.
The easiest way to open a DAT file is to double click on it then windows will  suggest you the program you should choose to open the file. If any of those programs do not open the file then the required program to open the file may not be installed on your computer.
If the DAT file is a video file you can use KM player which supports almost every video format so if the DAT file is a video file the player will be able to open it. KM player is a very good video player with good sound and video quality it also got the latest 3D technology.
You can download the player from below link. http://www.kmplayer.com/
