I am using an Android phone and I just want to know if its possible to play a high-resolution FLV files into it. If yes, what are the necessary steps needed? Do I need to install any special software to this? What are the system requirements needed?
How to play high resolution flv files in my android phone?
Hi Rochell T tritt
In order to play a high definition play you need to upgrade your Android to the right gingerbread or upwards unless you have Android 2.2 froyo and make sure that your player has 800Mhz processor. The appropriate software that suits Android phones include:
On the above links respectively you will be able to get much information on regards to the best players for Android phones. Best of Luck Rochell
