Grace_ford
Posted on - 11/05/2011
How can you play just one song on iTouch? I have meditation audio files which are 15-30 minutes long and have a bell at the end of the audio. After one file, the next one automatically plays. I have renamed the metadata of these files so they are listed in separate albums, but iTouch still plays one audio file after another.
How to Play One Song on iTouch
 The itouch has buttons that you can use to repeat and shuffle your music. To access these buttons, just follow the steps below. Images are also shown for easier understanding.
1. Tap underneath the left arrow button or the album title while the song is playing.
2. The repeat and the shuffle buttons will appear along with the song duration slider.
3. On the right-side of the bar that appears, select the REPEAT option until it appears with a 1 by it.
If the number "1" appears, that means that you are successful in setting a song to repeat.
